Lookup Select Box Variable based on other variable set by script
Hello
I've created a variable set with two variables: one is a select box 'Site', the other one is a lookup select box 'Warehouse' displaying values based on the 'Site' selection. This variable set is attached to several catalog items and this works fine on console and portal.
However, I have a case on a catalog item where the site should not be selected by the user. For that item, I've created an onLoad catalog client script that set the default value for 'Site', together with a catalog UI Policy that set the 'Site' field to read-only.
When requesting this item thru the console, it works fine: the list in the 'Warehouse' field is populated depending on the 'Site' value. However, this is not working on the portal. The default value is set for 'Site' but it seems it is not taken into account in the lookup select box.
Any idea is welcome!
Thank you in advance
Thank you for your help.
Actually, changing the variable type from lookup select box to reference, with the same reference qualifier does the trick
