Major Problem field not showing on New Problem record in SOW
Edgar10
So I have a requirement to include Major Problem field in the SOW form for Problem.
I' already configure the form and included it in the plaftform in SOW view however
On SOW when creating a new problem the field is not available.
When I open an existing problem record the Major problem is visible.
I've check some UI policy and Client scripts and can't find anything.
Edgar10
Found the solution.
So there are 2 view for SOW.In order to show the Major problem field in new record the field should be included in the view for SOW new record.
Ankur Bawiskar
@Edgar10
any field level READ ACL is hiding it for new record?
Hi Ankur ,
Nope. I don't find any field level ACL for major problem field.
Edgar
@Edgar10
are you sure you checked client scripts and UI policies and also UI scripts?
Edgar10
Found the solution.
