MRVS is not working on Portal
Monika2
Giga Guru
MRVS is not working while added the same on catalog item.
It throws below error on portal and failing to load SC_Catalog_Item widget.
java.lang.NullPointerException: Value in JsonObjects name/value pair cannot be null
Failing widget: 'SC Catalog Item' (3c29786e87133200e0ef0cf888cb0bdf)
Clearing this solved the issue, right? Can you mark this answer as Correct?
Marking helpful and Correct is seen as a reward for giving helpful and correct answers.
Thank you! 🙂
22 REPLIES 22
Willem
Tera Sage
When do you get the error? On opening the item?
Do you have a Catalog Client script running on the Catalog Item or Multi Row Variable set?
Hi Willem,
I am getting this error while I am accessing catalog item on service portal where I have added this variable set.
Yes I have catalog client script but that is on catalog item not on varaible set.
Monika
Can you share that script? Are you trying to set the MRVS or any other object/json in that script?
Sure but I tried the same MRVS for other catalog item where i have not created any catalog client script or UI policies there also it is showing the same issue.
Also I am able to reproduce the same in my PDI. Just wanted to know if this is a know issue with New York Version.
