MRVS is not working on Portal
Monika2
Giga Guru
MRVS is not working while added the same on catalog item.
It throws below error on portal and failing to load SC_Catalog_Item widget.
java.lang.NullPointerException: Value in JsonObjects name/value pair cannot be null
Failing widget: 'SC Catalog Item' (3c29786e87133200e0ef0cf888cb0bdf)
Clearing this solved the issue, right? Can you mark this answer as Correct?
Marking helpful and Correct is seen as a reward for giving helpful and correct answers.
Thank you! 🙂
22 REPLIES 22
What happens if you add a new MRVS?
Willem
Tera Sage
Can you share details of the MRVS? Are the Variables in it mapped to a field?
Can you share printscreen like this?:
Hi Monika,
Did you try clearing instance cache using cache.do and then logout and login
Can you clear the Variable Set Attributes and try that way? (move the text to Description if you want).
