MRVS is not working on Portal
Monika2
Giga Guru
MRVS is not working while added the same on catalog item.
It throws below error on portal and failing to load SC_Catalog_Item widget.
java.lang.NullPointerException: Value in JsonObjects name/value pair cannot be null
Failing widget: 'SC Catalog Item' (3c29786e87133200e0ef0cf888cb0bdf)
Clearing this solved the issue, right? Can you mark this answer as Correct?
Marking helpful and Correct is seen as a reward for giving helpful and correct answers.
Thank you! 🙂
22 REPLIES 22
Thank you! 🙂
Thanks Willem.
Sorry as I overlooked you reply.
Monika
Hopefully your're monitoring this...
I have a similar issue.
I do not have any Variable Set Attributes set. Field is empty.
Warning I get when trying to submit on portal is "(g_form) [NOACTION] Could not find UI Action: Submit"
DirkRedeker
Hi
Do you work on a language setting, different to "system (english)".
Just let me know.
BR
Dirk
No
