Need a regex to allow all characters and spaces, but no lower case letters. Valid length is 0 - 60.
Joe Taylor
Giga Guru
Need a regex to allow all characters and spaces, but no lower case letters. Valid length is 0 - 60 characters.
I want to use this in a multiline variable called "item_short_description".
Thanks.
11 REPLIES 11
Hi @Joe Taylor in regex A-Z refers all characters between A to Z in all capital letters /s refers to spaces 0 to 60 allows upto 60 characters
You can write a on change client script like below
    var pattern = /^[A-Z\s]{0,60}$/;
    if (!pattern.test(newValue)) {
  g_form.clearValue('variablename');
        g_form.showFieldMsg('variablename', 'Error message here ', 'error');
Thanks for the script.
But  I need all other characters:  !@#$%^&,   etc.
I was really hoping I could put in a NOT rules like [!a-z] and be done with it.
Hi @Joe Taylor got it you want to allow all special characters, in that case below script works. Kindly check.
    var pattern = /^[A-Z\s!"#$%&'()*+,-./:;<=>?@[\]^_`{|}~]{0,60}$/;
       g_form.showFieldMsg('test', 'Error message here ', 'error');
Negative Test:
Hi @Joe Taylor if your issue is resolved please accept the solution 🙂
Hi @Joe Taylor
Can you try this-
^[A-Z\s\W_]{0,60}$
Amit
