Need a regex to allow all characters and spaces, but no lower case letters. Valid length is 0 - 60.
Joe Taylor
Giga Guru
Need a regex to allow all characters and spaces, but no lower case letters. Valid length is 0 - 60 characters.
I want to use this in a multiline variable called "item_short_description".
Thanks.
11 REPLIES 11
SyamPrasanM
Hi @Joe Taylor .
Hope this answere is useful to your question, use the client script
Key Components:
  • Field Access: Uses g_form.getValue() to retrieve values from the short_description and description fields.
  • Regex Pattern:
    • var regex = /^[^a-z]{0,60}$/; checks for:
      • No lowercase letters ([^a-z]).
      • Length between 0 and 60 characters.
function onSubmit() {
// Get the values from the short_description and description fields
var shortDesc = g_form.getValue('short_description');
var desc = g_form.getValue('description');
// Define the regex pattern for 0-60 characters with no lowercase letters
var regex = /^[^a-z]{0,60}$/; // Allows any character except lowercase letters and restricts length
// Validate short_description field
if (!regex.test(shortDesc)) {
g_form.addErrorMessage("The Short Description must be between 0 and 60 characters and contain no lowercase letters.");
return false;
// Validate description field
if (!regex.test(desc)) {
g_form.addErrorMessage("The Description must be between 0 and 60 characters and contain no lowercase letters.");
return false;
return true;
Mule Syam Prasanna
SyamPrasanM
Hi @Joe Taylor .
Key Components:
  • Regex Pattern:
return false;
return false;
return true;
Mule Syam Prasanna
