Need client script
User_267
For a variable (number) - it should accept only whole number ex:12 after that it need to autopopulate as ($12.00) including decimal and dollar symbol.
If alphabets or or any other apart from whole numbers are entered then it should show error.
Danish Bhairag2
Tera Sage
Hi @User_267 ,
You can try below code
    // Check if the new value contains only numbers
    if (/^\d+$/.test(newValue)) {
        // Format the value as $xx.xx
        var formattedValue = '$' + parseFloat(newValue).toFixed(2);
        // Set the formatted value back to the field
        g_form.setValue('amount', formattedValue);
        // Display an error message
        g_form.addErrorMessage('Please enter a valid whole number.');
        // Reset the field value to the previous value
        g_form.clearValue('amount');
Danish
Even for numbers like 12 it is showing alert.
