Need help hiding a Workspace button based on reference record and logged-in user
dd31
I have created a button on Workspace using the Button component. I want to hide it based on two conditions:
The current record where the button appears has a reference in a specific table
The Assigned to field of current record should match the logged-in user.
Here’s what I did so far:
Created a Data Source (Transform ) to check these conditions.
Called that data broker from the Hide component visibility property of the button.
However, it’s not working as expected — the button isn’t hiding even when the conditions should match.
Could someone help me figure out what I might be doing wrong?
PFB SS for reference:
Thanks @Ankur Bawiskar ! I figured it out, the issue was that my Data Broker was pulling the assigned_to from another source where the record wasn’t being fetched properly. I removed that property from the Data Broker and used the correct source, and now the button visibility works as expected.
@dd31
so what logs say?
