Need help in ts_weight attribute
Pihu1
Hi Community,
What is ts_weight attribute for Number field ?How it works? By default  for Number field it's ts_weight=50 can we change it? .I have an issue in SEARCHING Number field ,I have a custom table with Number field whenever I am searching for Number it is not giving the result its showing No records to Display.  What might be the issue? Will it be fixed if I change ts_weight=50 value to 100.?
Pihu
Hi Pihu,
Any update to this ?Any follow-up required? if not
Kindly mark the answer as Correct & Helpful both such that others can get help.
Sandeep
My question is for Incident table. And Will it be fixed if I change ts_weight=50 value to 100.?
Pihu
It should be.
Hi Pihu,
Sandeep
