Need help with Reference qualifier on Catalog Item Variable
GaryJHayes
I am trying to set a Lookup select box to work with a dependant field.
The dependant field is called current.variables.request_source. (Possible values: internal/external)
This does a direct lookup from the Choices list of the backend table
The reference qualifier I am using is:
javascript: "name=u_XXX_access^inactive=false^element=u_work_type^dependent_value=" + current.variables.request_source + "^EQ"
This works correctly and exactly as expected in the Service Portal but in the Platform UI Service Catalog the menu is always empty
As a test I tried replacing the variable with a fixed string like this:
javascript: "name=u_XXX_access^inactive=false^element=u_work_type^dependent_value=" + 'internal' + "^EQ"
 Then it work in both Service Portal and Platform UI Service Catalog (but obviously is not dependant)
Anyone have any suggestions why this qualifier is not working in the Platform UI Service Catalog?
GaryJHayes
OK, so I figured out the answer myself and here are the details for anyone else who has this problem
While this technique works well of the Catalog Item when viewed from the Service Portal it needs to have additional configuration to make it work properly when accessing the Catalog Item from the Platform UI Service Catalog
On the Default Value tab(!) there is a Variable Attributes field and this needs:
ref_qual_elements=<variable used to filter>
In this instance:
ref_qual_elements=request_source
Which matches the "current.variables.request_source" specified in the 'Reference qual'
With this in place the filters work in the Request Item in both the Service Portal and Platform UI Service Catalog
13 REPLIES 13
Ankur Bawiskar
Hi Gary,
Can you try this; use toString()
also is the variable name correct request_source; did you check what value it stores?
javascript: "name=u_XXX_access^inactive=false^element=u_work_type^dependent_value=" + current.variables.request_source.toString() + "^EQ"
Mark āœ… Correct if this solves your issue and also mark šŸ‘ Helpful if you find my response worthy based on the impact.
Thank you for the quick response Ankur bu I tried with toString() and it made no difference
Mark Roethof
Hi there,
Looks pretty oke to me. Your use of current.variables is also valid.
I don't know the technical why yet, though a few weeks a go I stumbled on something similar and just removed the ^EQ part. It worked then somehow. Still have to find out why technically (also because this looks to be generated by default reference type).
So, try to remove:
+ "^EQ"
Kind regards,
Mark
LinkedIn
Community article list
Thank you for the quick response Mark but I tried without the "^EQ" and it made no difference
