need solution in client script
keval3
I have below requirement
I have wright one on change client script on choice field called purchasing group when choice of purchasing group will change at that time user list will remove. for that I have written  below client script
g_form.clearValue('user_list');
this client script is removing value from user list but I don't want remove it. it should stay when I change the value.
kindly let me know how to do it.
Thanks & Regards
KP
Anurag Tripathi
Giga Patron
I'm sorry can you elaborate?
If you don't want the value cleared then remove
-Anurag
Hi Anurag,
See in the choice field there are 3 option for ex: A,B,C when I Choose A at that time in user list field I am choosing 2 to 3 users and save the form after that I open same form again and select option B and again choose other 2 to 5 user from user list again save the form after that when I reopen the form and again select option A at that time previously selected user should be their as it is. right now it is removing the user. kindly let me know how to do it.
Krushna R Birla
Hi @keval3
If you want that user list value to be there, then you need to remove that g_form.clearValue('user_list'); line from your on change script.
If your requirement is different, let me know what you want to achieve so that I can help you.
If this solution resolves your query, kindly mark it as the accepted solution and give it a thumbs up.
Best Regards,
Krushna Birla
Hi Krushna,
Hi Anurag,
