Need to apply validation for set of fields using client script for checking length of each field in one go
Are Kaveri
 i have below requirement.
there are 3 ID fields where the length should not exceed 4000 characters and need to show error message when it is exceeding the limit.
I need to handle 3 fields in single validation by creating an array for above fields. can someone help me how to validate using client script.
Please help for minimising below script
code i written is on submit need to minimise below code .
var stud = g_form.getValue('student_id');
    if (stud.length != '' && stud.length > 4000) {
        g_form.showFieldMsg("student_id", "This field has a maximum character limit of 4000. Please revise and submit.", "error");
        g_form.addErrorMessage("You have exceeded the 4000 character limit. Please revise and submit.");
        return false;
    var stude = g_form.getValue('student_id1');
    if (stude.length != '' && stude.length > 4000) {
        g_form.showFieldMsg("student_id1", "This field has a maximum character limit of 4000. Please revise and submit.", "error");
        g_form.addErrorMessage("You have exceeded the 4000 character limit . Please revise and submit.");
        return false;
    var studen = g_form.getValue('student_id3');
    if (studen.length != '' && studen.length > 4000) {
        g_form.showFieldMsg("student_id3", "This field has a maximum character limit of 4000. Please revise and submit.", "error");
        return false;
Mahendra RC
Please check if the below code looks good to you and try once:
function onSubmit() {
    var isValid = true;
    var fieldNames = {
        "student_id": "Y",
        "student_id1": "Y",
        "student_id3": "Y"
    for (var fname in fieldNames) {
        var fieldValue = g_form.getValue(fname);
        if (fieldValue && fieldValue.length > 4000) {
            g_form.showFieldMsg(fname, "This field has a maximum character limit of 4000. Please revise and submit.", "error");
            if (isValid)
                isValid = false;
    if (!isValid) {
        return false;
With Array:
    var isValid = true;
    var fieldNames = ["student_id","student_id1","student_id3"];
        var fieldValue = g_form.getValue(fieldNames[fname]);
            g_form.showFieldMsg(fieldNames[fname], "This field has a maximum character limit of 4000. Please revise and submit.", "error");
            if (isValid)
                isValid = false;
    if (!isValid) {
        return false;
Please mark this as helpful/correct, if it answer your question.
Ankur Bawiskar
use onSubmit client script
function onSubmit(){
	var isValid = true;
	if (stud != '' && stud.length > 4000) {
		isValid = false;
	if (stude != '' && stude.length > 4000) {
		isValid = false;
	if (studen != '' && studen.length > 4000) {
		isValid = false;
	if(!isValid){
		return false;
could you please help me in form of adding above fields in an array and validating same fields in an array.
var arr=[ 'student_id' , 'student_id2' , 'stduent_id3' ];
then checking for validation?
@Are Kaveri
Was this a requirement from customer to use array? I don't think so.
For your requirement I already shared the working script.
this is for my requirement where we have 10 fields need to validate for each length which does not exceed 255 char limit and also need to write in single script using arrays for all 10 field in an array. your script also worked... it was not from customer but from my tech team they want me to use array instead of validating for each field...
thanks
kaveri
