08-25-2022 08:46 AM
i have below requirement.
there are 3 ID fields where the length should not exceed 4000 characters and need to show error message when it is exceeding the limit.
I need to handle 3 fields in single validation by creating an array for above fields. can someone help me how to validate using client script.
Please help for minimising below script
code i written is on submit need to minimise below code .
var stud = g_form.getValue('student_id');
if (stud.length != '' && stud.length > 4000) {
g_form.showFieldMsg("student_id", "This field has a maximum character limit of 4000. Please revise and submit.", "error");
g_form.addErrorMessage("You have exceeded the 4000 character limit. Please revise and submit.");
return false;
var stude = g_form.getValue('student_id1');
if (stude.length != '' && stude.length > 4000) {
g_form.showFieldMsg("student_id1", "This field has a maximum character limit of 4000. Please revise and submit.", "error");
g_form.addErrorMessage("You have exceeded the 4000 character limit . Please revise and submit.");
return false;
var studen = g_form.getValue('student_id3');
if (studen.length != '' && studen.length > 4000) {
g_form.showFieldMsg("student_id3", "This field has a maximum character limit of 4000. Please revise and submit.", "error");
return false;
Incident Management
08-25-2022 09:25 AM
Please check if the below code looks good to you and try once:
function onSubmit() {
var isValid = true;
var fieldNames = {
"student_id": "Y",
"student_id1": "Y",
"student_id3": "Y"
for (var fname in fieldNames) {
var fieldValue = g_form.getValue(fname);
if (fieldValue && fieldValue.length > 4000) {
g_form.showFieldMsg(fname, "This field has a maximum character limit of 4000. Please revise and submit.", "error");
if (isValid)
isValid = false;
if (!isValid) {
return false;
With Array:
var isValid = true;
var fieldNames = ["student_id","student_id1","student_id3"];
var fieldValue = g_form.getValue(fieldNames[fname]);
g_form.showFieldMsg(fieldNames[fname], "This field has a maximum character limit of 4000. Please revise and submit.", "error");
if (isValid)
isValid = false;
if (!isValid) {
return false;
Please mark this as helpful/correct, if it answer your question.
08-25-2022 09:25 AM
var isValid = true;
var fieldNames = {
"student_id": "Y",
"student_id1": "Y",
"student_id3": "Y"
if (isValid)
isValid = false;
if (!isValid) {
return false;
With Array:
var isValid = true;
if (isValid)
isValid = false;
if (!isValid) {
return false;
08-26-2022 04:17 AM
Thank you so much for your help 🙂
if i have to customise the error message
instead i want array values which exceed more than 4000 character limit with comma separated value?
Error message :
You have exceeded the 4000 character limit + fieldValues
could you please help me for adding it in error message
08-26-2022 06:12 AM
Hi Mahendra,
Your script helped me as well. Thank you so much for that.
I have similar requirement with little change in error message.
For example - I have 4 fields a,b,c,d exceeding limit of 4000 characters. I need to show error message in comma separated way.
Error Message should be in below way
" You have exceeded the 4000 characters for fields a,b,c,d. Please revise and submit."
Can you please help me in achieving this.
Thanks in advance....
08-26-2022 07:45 AM
Thank you so much
