Need to call RITM Variable from a Client UI action
anurag92
I am stuck in a tricky situation. I have a button on RITM form that opens a Service Catalog in a Dialog Window. I want variables in Window to be populated by variables of RITM.
UI Action is Client and has below code to get variables from RITM, but that does not work.
var z = current.variables.u_customer_name;
  var x = g_form.getValue('number');
var gr = new GlideRecord("sc_req_item");
gr.addQuery('number', y);
if (gr.next()) {
    y = gr.variables.u_customer_name;
z and y are returning Undefined values. Is there any other way to call RITM variables from UI action?
I did a lot of research on this, but couldn't find a solution.
The form looks like this:
I figured this out. It's not possible to call variables directly from client UI action, so I had to use a GlideAjax to get the variable values.
Can you please provide the solution so others can see.
Chad
