Need to copy worknotes from incident to incident tasks
Anjaneyulu1
Giga Contributor
Hii All,
I have written script like this,
when to run - after update
condition - work notes changes
script -
var inc = new GlideRecord('incident_task');
inc.addQuery('incident.sys_id', current.sys_id);
inc.query();
while (inc.next()) {
inc.work_notes = current.work_notes.getJournalEntry(1);
inc.update();
my script is not working but in place of worknotes if i place comments then it is working.
i don't know why it is happening like that.
please help me where i have written mistake here.
Hi Anji,
I just tested again and it is working:
If this answer is helpful please mark correct and helpful!
Christopher Perry
Chris Perry
20 REPLIES 20
chrisperry
Hi Anji,
The reason the work notes are getting duplicated between your incident and incident task is because these business rules will trigger each other. So when work notes changes on incident task, it triggers the business rule to post those work notes on the parent incident, and then because the work notes on the parent incident change it triggers the business rule to post those work notes back down to its child incidents.
In order to resolve this issue, you can add a check to your business rules to verify they aren't the same work note as below:
copy worknotes from tasks to incident BR:
    //var workNotes = current.work_notes.getJournalEntry(1);
    gr.addQuery('sys_id', current.incident);
    if (gr.next()) {
        var curWN = current.work_notes.getJournalEntry(1).match(/\n.*/gm).join('').replace(/^\s*\n/gm, "");
        if (gr.work_notes.getJournalEntry(1).match(/\n.*/gm).join('').replace(/^\s*\n/gm, "") == '' || gr.work_notes.getJournalEntry(1).match(/\n.*/gm).join('').replace(/^\s*\n/gm, "") != curWN) {
            gr.work_notes = curWN;
            gr.update();
            //gr.work_notes = workNotes;
})(current, previous);
copy worknotes from incident to tasks BR:
    // Add your code here
    inc.addQuery('incident', current.sys_id);
    inc.addActiveQuery();
    inc.query();
        if (inc.work_notes.getJournalEntry(1).match(/\n.*/gm).join('').replace(/^\s*\n/gm, "") == '' || inc.work_notes.getJournalEntry(1).match(/\n.*/gm).join('').replace(/^\s*\n/gm, "") != curWN) {
            inc.work_notes = curWN;
            inc.update();
I tested these code updates in your PDI and everything appears to be working properly.
Christopher Perry
Chris Perry
Hi Perry,
please check one more time because
worknotes are copying from incident tasks to incident.
but not from incident to incident tasks.
anjaneyulu.
Hi Anji,
Christopher Perry
Chris Perry
Hi Perry,
last but not aleast
I Have one more requirement
Create a custom Archive table and add fields (incident number, short description, priority, assignment group, assigned to, state).
Task: When an incident is resolved the selected field record should be copied on your custom table.
i have written script like this
in BR - After update
var inc = new GlideRecord('u_custom_archive ');
inc.initialize();
inc.u_incident_number = current.sys_id;
inc.u_short_description = current.short_description;
inc.u_priority = current.priority;
inc.u_assignment_group= current.assignment_group;
inc.u_assigned_to = current.assigned_to;
inc.u_state = current.state;
inc.insert();
for example :
if there are 50 or 100 fields are there in incident form & custom Archive table
now  here we can't write all fields in script part.
Is there any shortcut method to copy fields.
Anjaneyulu.
Hi Anji,
Since this question thread has already been marked as solved with correct answer, could you please start a new question thread for this new requirement? Once you create the new question thread, please share link here and I will reply as soon as I see it.
If this answer is helpful please mark helpful!
Christopher Perry
Chris Perry
