need to make variable mandatory and visible for specific group
pritimayee
Can anyone please help me on the below requirement. Need to make one variable visible when the logged in user is member of specific group and need to make mandatory if the variable request type is assign or delete.
12 REPLIES 12
Hi @pritimayee1@gmail ,
Just wanted to check with you, if the above response answered your question. If yes, then please do close this thread/question by marking the appropriate response as correct.
If you still need any further help or guidance on this then please update those on this question.
Please post your question if you are facing any issues in this. If not, then please do close this thread/question by marking the appropriate response as correct.
PavanK960672992
Mega Patron
Please close the thread by marking it as correct it has created long back and then it will be benefit for the other users.
Mark Correct if applicable, Thanks!!
Pavankumar
If it helps please click Accept as Solution/hit the Thumb Icon.
ServiceNow Community MVP 2024.
Pavankumar
