need to populate assignment group members in list collector field
‎04-28-2020 03:30 AM
Hi all,
I have group field(reference to group) when i select any group, that group members need to populate in list collector field(List collector reference to user ).
i want to show that particular group members in list collector field remaining group users i want to restrict...
Thanks in advance...
‎04-28-2020 05:16 AM
the blog explains how on change of reference variable you can set values automatically on the right hand side of the slush bucket
Did you get a chance to check that? I would encourage to check that and it will help you.
Can you share your complete script here?
‎04-28-2020 05:57 AM
Hi Ankur,
I am trying another way also to print(alert) selected assignment group members in alert..
alert(g_form.getDisplayBox('assignment_group').user);
is it correct..
‎04-28-2020 05:32 AM
Hello Lata,
When you select the group, do you see any users on your left side of the list? If yes, then selection of users has to be done manually.
Kindly mark the comment as a correct answer and helpful if it helps to solve your problem.
Asif
2020 ServiceNow Community MVP
‎04-28-2020 05:53 AM
i wrote same code in ref qualifier and default value attribute..when i select group and if i entered that group users i am unable to find users in left side..
‎04-28-2020 06:47 AM
Did you mention your actual group name in place of group_field?
If you are doing this on PDI, we can debug this together. you can call me on my number which is visible in my profile.
