need to populate assignment group members in list collector field
lata1
Hi all,
I have group field(reference to group) when i select any group, that group members need to populate in list collector field(List collector reference to user ).
i want to show that particular group members in list collector field remaining group users i want to restrict...
Thanks in advance...
27 REPLIES 27
since you want users to be shown in the slush bucket why to refer to sys_user_grmember table; you need to refer to sys_user table for this variable
Any reason for using sys_user_grmember table?
She wants to show the group members in the slush bucket of the selected group.
That's correct; but I think the variable should refer to sys_user table
I think pointing to sys_user_grmember will show record of Group Member and not user specific record;
Also sys_user_grmember doesn't have any field which is Display=True so it would always show sys_id in the slushbucket
Swapnil Soni1
Giga Guru
Hi Lata,
If you want to create in record producer or catalog Below are steps that I used to meet your requirement.
1. Created a record producer on Requested Item (you can change)
2. Add reference field for user.
3. Added ListCollecter.
Below are screen shots
Hope this will help you.
Please Hit ✅Correct, ⭐️Helpful depending on the impact of the response
Hi Swapnil,
sys id is coming..not user name
reference:
javascript:'group='+current.variables.group
Attribute:
ref_qual_elements=group,ref_ac_columns=group.name,no_filter
any change required for getting username?
