Need to populate display name based user given values
Haresh Haru
Hello All,
Like I have 3 fields are there which are single line text fields, so when user enter a value in first name as haresh and lastname as haru then the third field should population haresh haru as the display name in portal catalogue form..
Haresh
Anurag Tripathi
Mega Patron
You need 2 Onchange Client scripts running on first name and last name fields. On each script read the current field and combine it with second field and populate to third field
Something like below
var fName = g_form.getValue('<first name field>');
var lName = g_form.getValue('<last name field>');
g_form.setValue('<Full name field>', fname + lName);
-Anurag
@Haresh Haru
Try this
var fname = g_form.getValue('first_name');
  var lname = g_form.getValue('last_name');
  var ans = fname +  ' '  + lname.toString().toUpperCase();
  g_form.setValue('display_name',ans);
-Anurag
Hello @Anurag Tripathi
Its working as expected but if the user is giving first name also it has come first letter as capital like this 'haresh haru'  then it showuld show "Haresh HARU (Guest)"
can you please help me to get fisrtname first letter as upper case other letters in lower case
@Haresh Haru
USe this
  var ans = fname.toString().toLowerCase();+  ' '  + lname.toString().toUpperCase();
Please mark the response as correct if this answers your question.
-Anurag
sushantmalsure
you can write on change () catalog client script on related catalog item.
OnChange() function to be called on lastname , then set the 3rd field using value of first name and last name.
You may want to check if first name is not empty.
You can set this client script to run UI type as All or Service Portal and applies on catalog item view as true.
Regards,Sushant Malsure
