Need to send a notification to Author and KB owner for expiration of knowledge article?
Ramu6
Hi Al
 I have a requirement that  need to send  send a email notification to "Author ,KB owner and content owner" Whenever a knowledge article reaches 60 and  30 days before Valid to date?
If need to send warning notification exactly if valid to have due in 60 days and if due in 30 days also?
please help me to achieve to this
Ramu
@Ramu6
Try below code: which will give you articles having valid to from now at 30 days and 60 days
var gr = new GlideRecord('kb_knowledge');
gr.addEncodedQuery("valid_toRELATIVEGT@dayofweek@ahead@29^valid_toRELATIVELT@dayofweek@ahead@31^NQvalid_toRELATIVEGT@dayofweek@ahead@59^valid_toRELATIVELT@dayofweek@ahead@61");
while (gr.next()) {
gs.eventQueue('sn_hr_core.knowledge expiry', gr, gr.author, gr.kb_knowledge_base.owner);
Regards,Sushant Malsure
@sushantmalsure
Thanks for the code, but this also not work, it pulls many records of previous year also
So i want that if valid to date is due in 60 days , need to send notification or if valid to date due in 30 days then also need to send notification, but not two notifications, need to achieve it in one notification?
Ramu
Try below :
gr.addEncodedQuery("valid_toRELATIVEGT@dayofweek@ahead@29^valid_toRELATIVELT@dayofweek@ahead@31^valid_to>javascript:gs.endOfToday()^NQvalid_toRELATIVEGT@dayofweek@ahead@59^valid_toRELATIVELT@dayofweek@ahead@61^valid_to>javascript:gs.endOfToday()");
while (gr.next()) {
If above didnt work then I must say try this filter manually on list layout to confirm the result set.
I see its working fine on my PDI, you may also want to validate if we are using correct field name  'valid_to' and same is used by knowledge articles.
@sushantmalsure
how do i test it on my list view, because it contain
It should work in list view as well
https://<instanceName>.service-now.com/nav_to.do?uri=%2Fkb_knowledge_list.do%3Fsysparm_query%3Dvalid...
replace <instnaceName> with your instance
