No transform entry or scripts are defined
Supriya Waghmod
Issue : Imports set shows  error  'No transform entry or scripts are defined'.
Steps  1. Create request  and add csv file
            2. run the data source for received CSV via REQUEST
            3. Transform attachment - csv file details to Target table
1. created a catalog item : import tasks
2. Data source- 'FJ - Fragomen Import  and Transform map - FJ TM - Fragomen Case created
3. created script include- to run data source on creation of RITM(import task)
3.1  FJ_ImportProcessorAutomated
gs.include('FJ_StringUtil');
var FJ_ImportProcessorAutomated = Class.create();
FJ_ImportProcessorAutomated.prototype = {
initialize: function() {
this.extractFieldList = [
'sys_created_on',
'sys_import_row',
'sys_import_state',
'sys_row_error',
'sys_import_state_comment',
['sys_import_set', 'number'],
['sys_target_sys_id', 'number']
this.dataSource = 'FJ - Fragomen Import';
performImport: function(current) {
try {
this._removeExistingAttachment();
this._copyAttachment(current);
var res = this._initiateDataLoad(current);
return res;
} catch(error) {
gs.error('Error in Script Include FJ_ImportProcessorAutomated - performImport-' + error);
/*_________________________________________________________________
* Description: Used for validation of choice values before inserting during Data imports
* Parameters: Table Name and Choice Label
* Returns: Choice Value if present, else keyValue
* Note: Please use getDisplayValue() if you already have a reference to the target table
________________________________________________________________*/
getChoiceLabel: function(tableName, fieldName, keyValue) {
var res = '';
var grC = new GlideRecord('sys_choice');
grC.addQuery('name', tableName);
grC.addQuery('element', fieldName);
grC.addQuery('value', keyValue);
grC.addActiveQuery();
grC.query();
if(grC.next()) {
res = grC.label.toString();
res = keyValue;
return res;
* Description: Checks if a table state transition from existing value to new value is valid as per the business process of BCH
* Parameters: Table name, New state, Existing state
* Returns: TRUE or FALSE
* Note: newState needs to be a Choice Label value
checkValidStateTransition : function(tableName, existingState, newState) {
var res = false;
// tableName has not yet been configured as it is always Incident in this case.
existingState = parseInt(existingState, 10);
var incident = {
1:// New
['new','in progress','canceled'],
2:// In Progress
['in progress','on hold','resolved','canceled'],
3:// On Hold
['on hold','in progress'],
6:// Resolved
['resolved','in progress'],
7:// Closed
8:// Cancelled
if(incident[existingState].toString().indexOf(newState) > -1) {
res = true;
return res;
* Description: Check if any given user belongs to a group. This is required for transform map check to prevent users being assigned to incidents if they do not belong to a group.
* Parameters: group name and user ID
* Returns: TRUE/FALSE
checkUserGroupMembership: function(groupName,userID) {
var res = false;
var groupFlag = false;
var userFlag = false;
// Check if Group is valid
var grGrp = new GlideRecord('sys_user_group');
grGrp.addQuery('name', groupName);
grGrp.addActiveQuery();
grGrp.query();
groupFlag = grGrp.next();
// Check if User is valid
var grUser = new GlideRecord('sys_user');
grUser.addQuery('user_name', userID);
grUser.addActiveQuery();
grUser.query();
userFlag = grUser.next();
if(groupFlag && userFlag) {
// Check if user is a member of the group
var grMember = new GlideRecord('sys_user_grmember');
grMember.addQuery('group', grGrp.getUniqueValue());
grMember.addQuery('user', grUser.getUniqueValue());
grMember.query();
res = grMember.next();
return res;
_removeExistingAttachment: function() {
//Remove existing Attachments if present on the Data Source, before proceeding to Import
var grGetAttach = new GlideRecord('sys_attachment');
grGetAttach.addQuery('table_name', 'sys_data_source');
grGetAttach.addQuery('table_sys_id', this.dataSource); // sys_id of the Data Source
grGetAttach.query();
while (grGetAttach.next()) {
var grRemoveAttachment = GlideSysAttachment();
grRemoveAttachment.deleteAttachment(grGetAttach.sys_id); // Delete Attachments on the Data Source
_copyAttachment: function(reqItem) {
var copyAttach = new GlideSysAttachment();
copyAttach.copy('sc_req_item', reqItem.sys_id, 'sys_data_source', this.dataSource);
_initiateDataLoad: function(current) {
//load(/* Data Source */ , /* Transform Map */ )
// var res = new FJ_AutomatedDataLoad().load(gs.getProperty('fj.fragomen.data.source.name','FJ - Fragomen Import'), gs.getProperty('fj.fragomen.transform.map','FJ TM - Fragomen Case'));
var res = new FJ_AutomatedDataLoad().load('FJ - Fragomen Import','FJ TM - Fragomen Case');
return res;
_logErrors: function(res) {
var exportSet = [];
var exportStr = '';
// Generate the Output file with Error Log
if (JSUtil.notNil(res)) {
exportSet = this._retrieveRecords(res);
var crlf = '\n';
exportStr = exportSet.join(crlf);
return exportStr;
_retrieveRecords: function(queryString) {
var res = [];
res.push(this._extractFieldList());
var grOutputError = new GlideRecord('sys_import_set_row');
grOutputError.query('sys_import_set', queryString);
grOutputError.orderBy('sys_import_row');
grOutputError.query();
while (grOutputError.next()) {
res.push(this._getCSVRow(grOutputError));
return res;
_extractFieldList: function() {
var res = [];
var elements = this.extractFieldList.length;
for (var index = 0; index < elements; index++) {
res.push(this._getElement(this.extractFieldList[index]));
return res;
_getElement: function(element) {
var res = '';
var xtype = JSUtil.typeOf(element);
if (xtype == 'string') {
res = element;
} else if (xtype == 'array') {
res = element[0] + '';
return res;
_getCSVRow: function(grOutputError) {
var res = [];
var cnt = this.extractFieldList.length;
for (var i = 0; i < cnt; i++) {
res.push('"{0}"'.format(this._getFieldContent(grOutputError, i)));
return res.join();
_getFieldContent: function(grOutputError, index) {
var res = '';
var xtype = JSUtil.typeOf(this.extractFieldList[index]);
res = grOutputError.getDisplayValue([this.extractFieldList[index]]) ? grOutputError.getDisplayValue([this.extractFieldList[index]]) : '';
res = this._getFieldArrayContent(grOutputError, this.extractFieldList[index]);
return res;
_getFieldArrayContent: function(grOutputError, fieldArray) {
try {
var res = '';
var elements = fieldArray.length;
res = grOutputError.getDisplayValue([fieldArray[0]]) ? grOutputError.getDisplayValue([fieldArray[0]]) : '';
if (elements > 0) {
//for (var eleIndex = 1; eleIndex <= elements; eleIndex++) {
res = grOutputError[fieldArray[0]][fieldArray[1]] ? grOutputError[fieldArray[0]][fieldArray[1]] : '';
return res;
} catch (error) {
gs.error('Error in Script Include FJ_ImportProcessorAutomated - _getFieldArrayContent-' + error);
_createAttachment: function(current, content) {
var grAttachment = new GlideSysAttachment();
grAttachment.write(current, current.number + '-Fragomen Case Update Log-' + gs.nowDateTime().toString().replace(/:/g, '-') + '.csv', 'text/csv', content);
type: 'FJ_ImportProcessorAutomated'
2.2 FJ_AutomatedDataLoad   -- to run data source
gs.include("PrototypeServer");
var FJ_AutomatedDataLoad = Class.create();
FJ_AutomatedDataLoad.prototype = {
initialize: function() {},
load: function( /* Data Source */ source, /* Transform Map */ mapName) {
var res = this._load(source, mapName, false);
return res;
_load: function( /* Data Source */ source, /* Transform Map */ mapName, /* Delete Transform Map */ cleanMap) {
var sourceGr = new GlideRecord('sys_data_source');
sourceGr.addQuery('name', source);
sourceGr.query();
// if we have our data source continue
if (!sourceGr.next()) {
// gs.print('Did not find Data Source ' + source);
var map = new GlideRecord('sys_transform_map');
map.addQuery('name', mapName);
map.query();
// if we have a map we can now load and run the transform
if (!map.next()) {
gs.print('Did not find Transform map ' + mapName);
// gs.print('Loading Import Set ' + source);
var loader = new GlideImportSetLoader();
var importSetGr = loader.getImportSetGr(sourceGr);
var ranload = loader.loadImportSetTable(importSetGr, sourceGr);
if (!ranload) {
// gs.print('Failed to load import set ' + source);
//gs.print('Running Transform map ' + map.name);
var t = new GlideImportSetTransformer();
t.setMapID(map.sys_id);
t.transformAllMaps(importSetGr);
// gs.log('Import Set SYS ID--' + importSetGr.sys_id);
// gs.log('Import Set Reference--' + importSetGr);
return importSetGr.sys_id;
can you try to hard-code the sys_id of transform map
it seems you are having multiple transform maps with same name
15 REPLIES 15
