Not able to relate the change request to related list in Problem
kulkarnivivekn
In Problem,i have created the one reference field for change request based on if change required is YES and Problem state is resolved then the attached
change should display in related list->change request tab.
I have written below business rule but its not pushing to the change request in related field.
  // Add your code here
    var rec = new GlideRecord('change_request');
    rec.initialize();
    rec.change_request = current.rfc;
    rec.task = current.sys_id;
    rec.insert();
})(current, previous);
Please help me to do this.
It worked for me. Please check your work closely to my notes.
I added this Change Request -> Parent list on my related lists.
And here's the complete business rule used to trigger the script:
If that doesn't work, check your permissions closely to make sure the tester has create and write permission on the change_request table.
19 REPLIES 19
Still its not pushing change to related list.
Thank you so much now i am able to push change to related list.
Now i have one more query :
Problem state is 'resolved' and change required is 'yes' based on this condition only
Related list-->change request(Change request->Parent) should visible to user and Edit and New button should Omit.
Please help me to achieve this.
Please help me
If you want to make the visibility of the related list condition (show sometimes and hide others) use a client script using the method g_form.showRelatedList() and g_form.hideRelatedList().
Docs: Client Scripts
Docs: GlideForm
Client Script Best Practices - ServiceNow Wiki
To hide the New and Edit button, use the Configure> List Control option and check those boxes.
Configure list controls
Thank you so much its working fine for me.
If we add a new button "Download" that if selected it will download the Document from ServiceNow
above is the one more requirement if possible please help to achieve,
