ā01-30-2022 10:35 PM
I'm unable to retrieve MRVS data from onsumbit client script. I have a requirement to get the total value of seats into a variable outside of MRVS. I'm using on submit client script.
Below is the code which I tried
function onSubmit() {
var gr = g_form.getValue(#varibale set name);
var parser = JSON.parse(gr);
var sum = 0;
alert(parser);for(var i=0;i<parser.length;i++){
sum = sum + parseFloat(parser[i].seats); // variable name inside MRVS
alert(sum);
I'm getting gr value as empty and the total field is also not updating. Please help me in getting the total value into a variable outside of the multi row variable set.
Service Catalog
ā01-31-2022 12:05 AM
Hi Author,
To access the outside variables do the below
First, You would need to create an Onload script in your catalog item, with isolate script set to false:
function onLoad() {
//We need to make the g_form object for the parent item available for later
this.cat_g_form = g_form;
Once that is in place, you can use something like in a script on the MVRS (also set to isolate script false).
var multiRowVariableSet = JSON.parse(g_form.getValue('demo_variable_set')); // Replace your variable set Name and not label here.
var totalCost = 0;
for (var i = 0; i < multiRowVariableSet.length; i++) {
totalCost += multiRowVariableSet[i].Variable_Name; //add all totals from the MRVS to 1 total
alert(totalCost);
//Service Portal logic
if (this) {
this.cat_g_form.setValue('variable_name', 'totalCost');
//Native UI logic
parent.g_form.setValue('variable_name', 'totalCost');
ā01-30-2022 11:28 PM
what came in alert?
ā01-30-2022 11:29 PM
I got Empty value
ā01-30-2022 11:32 PM
can you share the MRVS variable set screenshot?
can you share screenshot of the client script
ā01-30-2022 11:47 PM
Variable set :
Client Script :
ā01-31-2022 12:22 AM
update as this
var gr = g_form.getValue('abc');
var sum = 0;
alert(parser);
alert(sum);
alert('total' + sum);
