ā01-30-2022 10:35 PM
I'm unable to retrieve MRVS data from onsumbit client script. I have a requirement to get the total value of seats into a variable outside of MRVS. I'm using on submit client script.
Below is the code which I tried
function onSubmit() {
var gr = g_form.getValue(#varibale set name);
var parser = JSON.parse(gr);
var sum = 0;
alert(parser);for(var i=0;i<parser.length;i++){
sum = sum + parseFloat(parser[i].seats); // variable name inside MRVS
alert(sum);
I'm getting gr value as empty and the total field is also not updating. Please help me in getting the total value into a variable outside of the multi row variable set.
Service Catalog
ā01-31-2022 12:05 AM
Hi Author,
To access the outside variables do the below
First, You would need to create an Onload script in your catalog item, with isolate script set to false:
function onLoad() {
//We need to make the g_form object for the parent item available for later
this.cat_g_form = g_form;
Once that is in place, you can use something like in a script on the MVRS (also set to isolate script false).
var multiRowVariableSet = JSON.parse(g_form.getValue('demo_variable_set')); // Replace your variable set Name and not label here.
var totalCost = 0;
for (var i = 0; i < multiRowVariableSet.length; i++) {
totalCost += multiRowVariableSet[i].Variable_Name; //add all totals from the MRVS to 1 total
alert(totalCost);
//Service Portal logic
if (this) {
this.cat_g_form.setValue('variable_name', 'totalCost');
//Native UI logic
parent.g_form.setValue('variable_name', 'totalCost');
ā01-31-2022 12:50 AM
Not working.
var gr = g_form.getValue('abc');
this is not holding any value.
ā01-31-2022 01:11 AM
we are getting this error while adding a row in MRVS
ā01-31-2022 01:41 AM
did you check which script is that?
ā01-31-2022 01:46 AM
yes. regarding the same script which I'm working on
ā01-30-2022 11:25 PM
Try the below script.
var value = g_form.getValue('MRVS_FIELD_NAME');
var multiJson = JSON.parse(value);
var sum = 0;
for(var i = 0; i<multiJson.length; i++)
//execute all the rows of mrvs
if(multiJson[i].MRVS_FIELD_SEAT){ //if seat is not empty then
var t = multiJson[i].amount;
sum = sum + Number(t);
g_form.setValue('FIELD_NAME',sum);//field outside of MRVS
Mark this as Helpful/Correct if Applicable.
Sourabh
