ā01-30-2022 10:35 PM
I'm unable to retrieve MRVS data from onsumbit client script. I have a requirement to get the total value of seats into a variable outside of MRVS. I'm using on submit client script.
Below is the code which I tried
function onSubmit() {
var gr = g_form.getValue(#varibale set name);
var parser = JSON.parse(gr);
var sum = 0;
alert(parser);for(var i=0;i<parser.length;i++){
sum = sum + parseFloat(parser[i].seats); // variable name inside MRVS
alert(sum);
I'm getting gr value as empty and the total field is also not updating. Please help me in getting the total value into a variable outside of the multi row variable set.
Service Catalog
ā01-31-2022 12:05 AM
Hi Author,
To access the outside variables do the below
First, You would need to create an Onload script in your catalog item, with isolate script set to false:
function onLoad() {
//We need to make the g_form object for the parent item available for later
this.cat_g_form = g_form;
Once that is in place, you can use something like in a script on the MVRS (also set to isolate script false).
var multiRowVariableSet = JSON.parse(g_form.getValue('demo_variable_set')); // Replace your variable set Name and not label here.
var totalCost = 0;
for (var i = 0; i < multiRowVariableSet.length; i++) {
totalCost += multiRowVariableSet[i].Variable_Name; //add all totals from the MRVS to 1 total
alert(totalCost);
//Service Portal logic
if (this) {
this.cat_g_form.setValue('variable_name', 'totalCost');
//Native UI logic
parent.g_form.setValue('variable_name', 'totalCost');
ā01-31-2022 01:08 AM
Have you try the above code?
ā01-30-2022 11:25 PM
Is "alert(g_form.getValue('variable_set_name'));" giving you undefined?
Can you do a screenshot of the actual variable set and name, because this should give you the value of the mrvs, and the client script with alert as this, and the end result.
ā01-30-2022 11:39 PM
Please update your script as below :
var totalCost = 0;
alert(totalCost);
//g_form.setValue('Variable Name',totalCost);
This is working for me in my PDI.
Shloke
ā01-30-2022 11:58 PM
Hi thank you but its not working
ā01-31-2022 12:25 AM
Can you share the version of code which you have written to assist you further?
Shloke
