Not able to see "Knowledge" check box on Incident form
Options
03-05-2026 01:01 AM
Hi Team,
I was unable to see the “Knowledge” checkbox on the Incident form under the Resolution section. Although it was already added to the form layout, the field was disappearing once the form finished loading.
Can I get any help to fix this.
Akhil
13 REPLIES 13
Options
05-31-2026 09:35 PM
@VanamaA
Hello.
I have same issu.
Has this case been resolved?
Options
05-31-2026 09:57 PM
I saw KB1437037, but I don't have com.snc.incident.knowledge installed.
Also, even if the status is closed, the knowledge checkbox does not appear.
If anyone has solved it please let me know.
Options
06-01-2026 01:43 AM
Options
06-01-2026 01:44 AM
You need to install plugin for this
