Not working flow
‎08-03-2023 07:19 AM
Hi Team,
we have one variable on catalog item called "return" date"which type is date which will only visible when RITM is in pending requestor state.
we have flow designer on that catalog item and through which we are creating one task so my requirement is after closed 1st task I am checking Return date is empty so I puting ritm is on pending requestor state and when user will submit the return date on form then RITM will be in "in-progress state and new task is generated.
I have created flow like below but it is not working
I am trying to do in below flow. I had to check if return date is empty but there was no option available "is empty " for date type field so I have create set flow variable and set string,
Than I am checking If return date is empty then RITM should be go in pending requestor state and when user submit return date then ritm should be go in in progress and create new task
But what is happening now it is checking date is empty then setting ritm in pending requestor state and then suddenly putting ritm in inprogress state and creating new task even still date is empty
Can someone please help me here please..?
