data send to rest post method message using flow designer
Hi all ,
I am using a REST message with the POST method in Flow Designer. I am sending two input fields: phonenumber and workphone. I have created the REST message, set the endpoint, and configured basic authentication. Below is the preview script I’m using:
Can anyone confirm whether this script is correct or needs improvement?
    var phonenumber = inputs.phonenumber;
    var workphone = inputs.workphone;
    try {
        var r = new sn_ws.RESTMessageV2('xyz rest message', 'post message');
        // If you're using parameters in the REST message body template
        r.setStringParameterNoEscape('phonenumber', phonenumber);
        r.setStringParameterNoEscape('workphone', workphone);
        // Alternatively, if you're building the body manually:
        // var requestBody = JSON.stringify({
        //     "phonenumber": phonenumber,
        //     "workphone": workphone
        // r.setRequestBody(requestBody);
        var response = r.execute();
        var responseBody = response.getBody();
        var httpStatus = response.getStatusCode();
        // Optionally log or output the response
        outputs.responseBody = responseBody;
        outputs.httpStatus = httpStatus;
        output.responseBody=responseBody;
    } catch (ex) {
        var message = ex.message;
        outputs.error = message;
})(inputs, outputs);
while the script i am receiing the status code :
{ "Action Status": { "code": 0, "message": "Success" } }
I amreceving the three logs :
2025-09-26 02:54:35WarningEncountered undeclared output variable: error
2025-09-26 02:54:35WarningEncountered undeclared output variable: httpStatus
2025-09-26 02:54:35WarningEncountered undeclared output variable: responseBody
Can you help me how to resolve the problem.
Thanks and Regards,
Chandan
Missing s in output:
 outputs.responseBody=responseBody;
another output message is coming :
error :"output" is not defined.
Anand__99
Hi @Community Alums ,
Under the script action you need to defined your variables in output variables section.
Anand
If this solves your query mark this as correct to close the thread.
