Notification
dixitreddy
i have a multiple check box under labels in catalog form so which check box is selected i should get it in email notification
Dr Atul - LNG
Hoi @dixitreddy
These are just variable values, not the checkbox for notifications. Once you submit the request, the email will be triggered automatically.
in the email is should get like the selected software is (selected checkbox in the form)
Hi @dixitreddy https://www.youtube.com/watch?v=9s8VaTXdH4A
https://www.youtube.com/watch?v=jwXU9MQ8xhQ
Ankur Bawiskar
@dixitreddy
since those are checkbox type, they will give you true/false value
Do you want the tickbox symbol in email?
