On hold reasons
keerthana10
how to configure this scenario ,
What-Review the current on hold reason but only have awaiting caller state to stop the SLA clock
Why-to provide accurate SLA stats. awaiting caller should be the only state to stop the clock. the colleague doesn't care if It are waiting for an internal process such as change, problem or a 3rd party.
thanks,
Hi @keerthana10
Please accept the answers and close the thread.
20 REPLIES 20
Hi @keerthana10
Share some screenshots, where are you checking? Is SLA attached to Incident? If yes, then try to navigate from there.
screen shot attached here
You have just 2 SLA, and that is again response type, and in response type we didn't add onhold reason. There must be a resolution SLA as well.
AshishKM
Hi @keerthana10 ,
Do you already have configured SLA, which is pausing during the "On Hold" status.
During the On Hold, the SLA will be pause and business duration will not increase.
You need to review existing SLA ( or create new one ) and check the current pause condition and update accordingly.
The pause condition should be like below and set the Sub-Status = Awaiting Caller.
-Thanks,
AshishKM
Hi ,
now if i will create the new Sla , how to configure like Target its (response or resolution).
please guide to me.
