On Select Reference field variable & populate select box variable
Km Sh
Hello Team,
We have Reference variable in a Catalog form, when reference value is selected then auto populate the select box variable with the corresponding pairs as shown below:-
Reference VarSelect box Var
AS1041APAC
AS1039APAC
AS1149EMEA
AS1057EMEA
BS1054Canada
BS1725Canada
BS1578Canada
Hi @Km Sh
Can you do something like you can create one field in your custom table and in that field you can store the value of Select box variable , if it is possible you can simply glide on that custom table and in addQuery('sys_id', newValue)  and in if condition you can able to set the value of that field.
   gr.addQuery('sys_id', newValue);
   if(gr.next()){
	g_form.setValue('select_value', gr.select_value);
        g_form.update();
Please mark my answer correct and helpful if this works for you
Thanks and Regards
Sarthak
