06-11-2019 04:41 PM
Looking for some help in how to effectively set up a 4 person On-call rotation where the same person is on-call the same day of the week, Monday - Thursday. Then the weekend (Fri-Mon am) is a rotation. Something like this:
Person A - always on-call Mon 8am-Tues 8am
Person B - always on-call Tues 8am-Wed 8am
Person C - always on-call Wed 8am-Thu 8am
Person D - always on-call Thu 8am-Fri 8am
Each person rotates each Fri 8am - Mon 8am
The only way I can manage to get this working is by having 5 separate rotations, which doesn't seem right. I could use some guidance on this one.
06-12-2019 05:06 AM
Ok. First a correction to the property name. In my previous post I missed the full name. The full name is - com.snc.on_call_rotation.factor_daily_rotation_interval_all_day
When you create the schedule via wizard we also populate the 'Rotation Start Time' field in Roster to 08:00:00. So, please check for a new schedule after you have the property set.
If it is a existing schedule you are modifying please use the workaround of marking Rotation interval - 'weekly' and setting the 'Rotation Start Time' and again switch it back to Rotation Interval - Daily
At the end of it ... you should have a schedule like this. Here, I have two persons rotating daily
The schedule used is:
The Roster fields are set as:
The property is set as:
If it still does not work help me with these question - which release are you on? Can I have screenshots of your schedule attached to roster, The field values in roster and the property value and the Calendar?
Soumya
06-12-2019 05:06 AM
Soumya
12-25-2019 04:11 AM
Hi Member,
I have posted a requirement on on-schedule, can you let me know whether we can achieve through on-call schedule.
