onchange client script, oldValue is not coming in the alert.
Its a Yes/No catalog variable. I have written a onchange client script. The requirement is something like "if the particular field changes from Yes to No, do the logic".
So i wrote like below, if (oldValue is Yes & newValue is No) but its not working. Even the alert in the 5th line is empty for oldValue, newValue alert is coming.
then clear it only when the value selected is None
    if (isLoading){
    if(newValue == 'Yes'){
        g_form.setValue('hiddenVariable', 'Yes');
    else if(newValue == ''){
        g_form.clearValue('hiddenVariable');
    if(g_form.getValue('hiddenVariable') == 'Yes' && newValue == 'No'){
        // your logic
18 REPLIES 18
That the validation is not working, is as expected and correct. newValue does not work this way. That's why I was asking for more details on your case. What you are describing will not work with using oldValue. oldValue is the original value, this is not the value from before an onchange, its the original value from the form load.
Kind regards,
Mark
2020, 2021 ServiceNow Community MVP
2020, 2021 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
Thanks Mark, then do you have any idea how can i implement this? show alert only when value changes from Yes to No.
Ankur Bawiskar
Where is this not working?
Did you set UI Type - ALL for your client script
Does your variable has Include None as well?
In the serviceportal Ankur.
Yes UI type is All and my variable include none as well.
OldValue is getting empty, newValue is coming in the alert properly.
Screenshot 1 :
Screenshot 2 :
From the pics you can see that Old is getting empty.
Any input to my questions?
Like I asked, please describe your case more. I suspect this is about entering a new Catalog Item. As I mentioned, then using your approach is not correct. If my answer helped you in any way, please then mark it as helpful.
Kind regards,
Mark
LinkedIn
