OnLoad client script does not run to non-admin role (non-admin role/user has ITIL)
Antonio42
Team,
I created an onload client script to set category, assignment group and other fields to speed up the fill out of form, you guys know time is money 🙂
Everything works nice when I create a new incident since my userID is associated with admin role, but when any user out of admin role goes to new incident, the onload client script does not work, that user has ITIL role, ok? Have you already seem this before? Appreciate any help!
Then in that case you can directly have view name to compare in the script. try below script
function onLoad() {
    var viewName = getView();
        if(grView.name == "default"){ //here you know for which view the script should work. so you can directly compare view name. if it should apply for multiple views, you can have or (||) condition in if().
            g_form.removeOption('u_qs_type','Alert');
            g_form.removeOption('u_qs_type','Incident');
              if (g_form.getValue('category')=='' || g_form.isNewRecord() == 'false'){
                g_form.setValue('category', '1');}
            if (g_form.getValue('assignment_group')=='' || g_form.isNewRecord() == 'false'){
                g_form.setValue('assignment_group', 'ab08f792db946b006769980c8a961455');}
let me now for any query.
Ali
It is recommendation from service now that we should not use GlideRecord(server side) code in client scripts. instead use GlideAjax
