Only need members part of particular group to be visible
‎08-06-2023 10:55 PM
I have a requirement to create a field which is of type reference, and it is referring to sys_user table but i have a requirement that the users which are part of one of the particular groups should only be visible. How to do this please do share pointers and script if required to achieve this.
Thanks in advance.
‎08-07-2023 02:48 AM
Hi @Kalyani Jangam1 ,
The script include is not client callable and for reference qualifier though I selected as advance and adding code it is automatically getting changed to simple only.
‎08-07-2023 04:59 AM
yes it getting changed to simple no issue. Used gs.addInfoMessge in script include and check where code will stuck.
Please try and let me know if still not work.
‎08-07-2023 01:56 AM
You can refer to this documentation
