Onsubmit catalog client script is not aborting the form from submitting.
Kruthik M Shiva
I have created a on submit client script if the condition is matched it should give alert message and abort action i have used return false but still form is getting submitted what could be the possible issue and how to fix it, please share if anyone has pointers on this.
Thanks in advance.
Kruthik Shivaprasad
Hi @Kruthik M Shiva
Add one more line "return false" to the bottom of the client script. It should work
function onSubmit() {
    /*** Pop this gem into your script! */
    if (g_scratchpad.isFormValid) {
        return true;
    var actionName = g_form.getActionName();
    var ga = new GlideAjax('x_intellectu.CheckRetired');
    ga.addParam('sysparm_name', 'CheckingRetired');
    ga.addParam('sysparm_ia_name', g_form.getValue('ia_name'));
    ga.getXML(RetiredCheck);
    function RetiredCheck(response) {
        if (answer == 'true') {
            alert('This is retired');
            return false;
        g_scratchpad.isFormValid = true;
        g_form.submit(actionName);
	return false;
Cheers,
Tai Vu
12 REPLIES 12
Hi @Tai Vu
tried this code but still getting submitted
Thank you
Hi @Kruthik M Shiva
Did it come to the IF Condition with the alert?
We need to check what was this function return in your test case. => CheckingRetired
It is returning true in our case.
var CheckRetired = Class.create();
CheckRetired.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
CheckingRetired:function(){
var found;
var ianame = this.getParameter("sysparm_ia_name");
var dup = new GlideRecord('x_infte_ia');
dup.addQuery('asset_name', ianame);
dup.query();
if(dup.next()){
if(dup.status==6){
found = 'true';
else{
found = 'false';
return found;
type: 'CheckRetired'
Hi @Kruthik M Shiva
        return true;
            return false;
	return false;
Cheers,
Tai Vu
Kruthik M Shiva
Hi Jaspal,
Please find below script the alert is coming when clicked on submit but once click on ok on that popup the form is getting submitted.
                return false;
