Ordering Reference field Drop down
tonystark
Mega Expert
I m having a custom table which i set as a reference for one of my dropdowns(Reference field made as dropdown). Is there a way where i can set the order in which the order would be displayed in my dropdown?
In my dropdown, records are being displayed in the alphabetical order., but i want those records to display in the same order as in my table.
Tony
ctomasi
j3sus
Giga Contributor
Use dictionary attribute Reference sequence.
For example with value sys_updated_on if you want to order by the date in which the records were updated
