Parallel Approvals in Flow Designer Not Working: Flow Logic - Do the Following Parallel
Options
08-26-2024 12:13 AM
Parallel Approvals in Flow Designer is not working, it is triggering Approvals for all but once any one approved it gets closed for all.
When using Multiple "Ask For Approval" Actions inside a "Do the following in parallel" Flow Logic seeing that the Decision from the First Approval is being applied to all of the Approvals.
Options
08-26-2024 06:46 AM
Can you share more about your configuration? Without knowing what your flow is doing and until what it needs to do that, there are thousands of things that can cause this.
