Pass Order Guide Variables to Catalog Task Without Showing in in each Catalog item in Order Guide
jwagner
I've created a new hire order guide with the several variables I'd like to share across all included catalog items.
Common info I'd like to have on all catalog tasks: Supervisor/First Name/Last Name/Shift/Title/Department/EmployeeID
Catalog items: Build Computer/ Setup Phone/ Setup Email/ Create Access
There is no need for the user to see all those fields listed on each catalog item within the order guide, but I want to pass the variables to help the fulfiller.
and the following set of informaktion I'd like to carry over to each catalog item, but
Brent Sutton
Hi Ya,
Create the common variables in a variable set and include the variable set on the order guide and all catalog items that can be selected in the order guide. In the variable set you need to create an onload client script with UI Type set to "All" so it runs on both platform and Service Portal. Should look something like this:
function onLoad() {
	if (window === null) {
		// check if we are in an order guide using the g_service_catalog api for Service Portal and Mobile
		var isOrderGuide = g_service_catalog.isOrderGuide();
		if (isOrderGuide) {
			//call function to hide the fields on the catalog items if this is an order guide.
			hideVariables();
	else {
		var item = gel("current_item");
		var guide = gel("sysparm_guide");
		if (item != null && guide != null && item.value != guide.value) {
			hideVariables();
	function hideVariables(){
		g_form.setDisplay('your_var1',false);
		g_form.setMandatory('your_var2',false);
		g_form.setDisplay('your_var2',false);
On the order guide tick "Cascade variables" option which will copy the value of the data captured in the order guide down to the Service Catalogue items
That should now hide the variables, when displayed within an order guide. More information can be found about cascading variables at the following link - Cascade an order guide variable
Let me know how you get along.
Brent
P.S. If my suggestion helped then please mark as helpful and/or correct so other community members can benefit from this information.
12 REPLIES 12
venkatesh6
Kilo Explorer
I am still facing this issue in Service Portal side.
If i am selecting variable at describe needs , it is not visible as the selected value to the catalog items. So, the user is getting confused whether the value is selected or not.
If you can see the below screenshots - I selected New hire at the order guide initial page, but it is not displaying at the items section.
It is visible only at the last catalog item variable section.
Can you please help me onthis, as i am facing this issue since somany days.
Attaching you the script written for Variable set:
Hi Ya, Change the order of your setMandatory and setDisplay statements in the hideVariables function. Variables must not be mandatory when hiding them.
g_form.setMandatory('employee_status',false);
g_form.setDisplay('employee_status',false);
Brent
PS0166
