Pause Duration for SLA's
VanamaA
Hi Team,
We have a requirement that we need to have a field which will calculate the Business Pause Duration of SLA excluding the time between Resolved to Closed.Screenshot 2026-03-12 153620.png
Can we achieve this or do we have anything in OOB
Thanks and Regards,
Akhil
9 REPLIES 9
This is OOTB, and the work OOTB, if  you want to just capture on hold time you need to build logic by own mate. what is your exact case?
Hi @Dr Atul - LNG
It should calculate only the Business time where the incident was onhold.
Thanks,Akhil
Mate, SN provides specific fields have a look on same, these are OOTB only.  else you need to build own logic
PankajK67712898
Hi @VanamaA ,
Can you by just removing the "state is resolved condition" from pause condition and check if this fixes your issue.
If this helped you, please mark this helpful and accepted.
Hi @PankajK67712898
If we do that, the SLA will still running even when the Incident is resolved.
