Populate group member based on group selected
Bindhu1
I have below 2 variable, based on group selection , group member should get populated [each group has only one member]
1.approval_group: referring to sys_user_group table
2.approver: referring to sys_user table
tried below script, its not populating member, please help me here
script include:
var GetApproverByGroup = Class.create();
GetApproverByGroup.prototype = Object.extendsObject(AbstractAjaxProcessor, {
   getApprover: function() {
       var groupSysId = this.getParameter('sysparm_group');
       var userSysId = '';
       if (groupSysId) {
           var gr = new GlideRecord('sys_user_grmember');
           gr.addQuery('group', groupSysId);
           if (gr.next()) {
               userSysId = gr.user.toString();
       return userSysId;
Onchange client script : on change of group variable
   var ga = new GlideAjax('GetApproverByGroup');
   ga.addParam('sysparm_name', 'getApprover');
   ga.addParam('sysparm_group', newValue);
   ga.getXML(function(response) {
       var approver = response.responseXML.documentElement.getAttribute("answer");
       if (approver) {
           g_form.setValue('approver', approver);
Shivalika
Hello @Bindhu1
Use below 👇 script include
   // Function to get the first group member
       var userSysId = '';
       if (groupSysId) {
           // GlideRecord to get group members
           // Fetch the first user in the group
           if (gr.next()) {
               userSysId = gr.user.toString(); // Getting user Sys ID
       return userSysId; // Return user Sys ID
Use below 👇 client script
   ga.addParam('sysparm_group', newValue); // Send group Sys ID
       if (approver) {
           g_form.setValue('approver', approver); // Set the approver field with the user Sys ID
Is the approver field also reference fields ? Because you are passing sys_id ?
Also, is the Client script set to UI type ALl and the script include with "Client callable" box checked ?
If all above is correct then make use of response directly to populate.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this questions from unsolved to solved bucket.
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeEISQCY
16 REPLIES 16
@Bindhu1 I already recommended this method in my above response. That you can use response string directly.
Shivalika
@Bindhu1
Did the script I shared work fine?
As per new community feature you can mark multiple responses as correct.
@Bindhu1
If yes then you can mark my response correct as well and it's allowed as per new community feature.
Thanks in advance !
J Siva
Hi @Bindhu1
Try below script. I just tested out in my PDI.
Script include:
        var userSysId = '';
        if (groupSysId) {
            if (gr.next()) {
        return userSysId;
Client script:
    ga.getXMLAnswer(getResponse);
function getResponse(answer) {
    if (answer) {
        g_form.setValue('user', answer);
Siva
Shivalika
Hello @Bindhu1
       var userSysId = '';
       if (groupSysId) {
           if (gr.next()) {
       if (approver) {
Shivalika
