Populate lookup selectbox choice based on reference field
Sriharsha3
Hello ,
I have two variables Reference and lookup selectbox both referencing same table.
My requirement is: Both are referencing Business Application table. However the lookup select box field's lookup value field is  install_type
How to populate the install_type of selected application on the Select box field.
Eg: Application A install type is Production. So when i select Application A on the reference field, lookup field should populate with Production choice.
Hi Param,
If you still need that to be show and present then please find below suggestions
1) Since you just want to auto-populate Install Type based on application selected; please use single line text variable
2) use onchange on Reference variable to populate it
3) set it read-only from that script
Sample Client Script:
Note: Ensure you use proper variable name for
1) business name reference variable
2) install_type variable
3) install_type field from business app table
   if (isLoading) {
// always set as read-only
g_form.setReadOnly('install_type', true;)
if(newValue == ''){
g_form.clearValue('install_type');
var ref = g_form.getReference('business_app', callBackMethod);
function callBackMethod(ref){
if(ref.install_type != ''){
g_form.setValue('install_type', ref.install_type);
Mark āœ… Correct if this solves your issue and also mark šŸ‘ Helpful if you find my response worthy based on the impact.
16 REPLIES 16
please share screenshot
First variable: Reference field with two columns. But Display field is Application Name.
Second variable: Lookup Select Box on install type field of Business Application Table.
Second variable should be populated  with install type based on application selected.
Hope i have explained !
Thanks Param for the elaborating. It helps.
If I understand when,
Test1 is selected, Install Type should be set as On-Premise automatically.
Test2 is selected, Install Type should be set as Cloud.
If so, how are Column1 (Test1) & Column2(Install Type) related & what are the field names. Like application, install_type, etc.
Hello Jaspal,
You are right.
Variable 1: Column 1- Name
                 Column 2- install_type
variable 2: install_type
Hope this helps
You dont have to create 2 fields and populate it separately, you can use the field of the related table on this form. It will be controlled by the referenced record.
Use Configure Form Layout to bring install_type field on the form dot walking on application name field.
