Populate lookup selectbox choice based on reference field
Sriharsha3
Hello ,
I have two variables Reference and lookup selectbox both referencing same table.
My requirement is: Both are referencing Business Application table. However the lookup select box field's lookup value field is  install_type
How to populate the install_type of selected application on the Select box field.
Eg: Application A install type is Production. So when i select Application A on the reference field, lookup field should populate with Production choice.
Hi Param,
If you still need that to be show and present then please find below suggestions
1) Since you just want to auto-populate Install Type based on application selected; please use single line text variable
2) use onchange on Reference variable to populate it
3) set it read-only from that script
Sample Client Script:
Note: Ensure you use proper variable name for
1) business name reference variable
2) install_type variable
3) install_type field from business app table
   if (isLoading) {
// always set as read-only
g_form.setReadOnly('install_type', true;)
if(newValue == ''){
g_form.clearValue('install_type');
var ref = g_form.getReference('business_app', callBackMethod);
function callBackMethod(ref){
if(ref.install_type != ''){
g_form.setValue('install_type', ref.install_type);
Mark āœ… Correct if this solves your issue and also mark šŸ‘ Helpful if you find my response worthy based on the impact.
16 REPLIES 16
Hi Anurag,
Thanks for answering.
I'm dealing with variables of a catalog item and not on the form level.
Please suggest
Hi Param,
As said by Anurag; no need to create variables referring to same table
User can see the Install Type there itself then why to populate it again?
No need of extra variable
Hello Anurag,
The second variable is needed for confirmation and for viewing in Sc Task forms.
I need to populate the related column again on the select box variable.
Hi Param,
Are you saying you want only Lookup select box variable to be shown and not the Reference variable?
Any specific business requirement for this?
Hi Anurag,
Both the variables are to be shown.
Requirement is simple to show Install type in another variable based on the selected application.
