Possible to convert a Record Producer to a Catalog item?
incrypto
I have a couple large record producers (one has 73 variables) and I need to change them to Catalog Items. The original versions are client-facing forms that generate a Case; I've copied them and made them internal only and need to turn them into Catalog Items. Is this possible? And if so, how?
My normal method of converting a Catalog Item to a Record Producer by simply changing the Class is not an option (only Record Producer is available to select from the "Class" list). This is the case for all of the Record Producers I tested this on.
Thank you!
Steve
Just quickly tested this, thought will be quick then finding the topic 🙂
var gr = new GlideRecord('sc_cat_item');
if(gr.get('7434fcaf4f228410e7fe0ab18110c7dc')) {
	gr.setValue('sys_class_name', 'sc_cat_item');
//	gr.setValue('sys_class_name', 'sc_cat_item_producer');
	gr.update();
And the background script showing:
Change in class detected, switching from: sc_cat_item_producer to: sc_cat_item sys_id: 7434fcaf4f228410e7fe0ab18110c7dc
Looked at the list and the Record Producer (or now Catalog Item): looks fine! Obviously do test carefully and maybe even make an export to be sure.
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
12 REPLIES 12
That is not possible.
Either create new fields or go to each field and manually change the mapped Catalog Item name.
Where to write the script?
I have created UI Actions for this function, in case someone needs it.
