Predictive Intelligence Similarity Solution Enable in Platform UI
vinitha3
Solutions built using Similarity Framework are available in Agent Workspace.
How can they be made available in Platform or Native UI?
I could not spot a way to activate the same.
Vinitha
vinitha3
Hi Both,
Thank you so much for enlightening with the links.
Actual config that helped is "Search on Tab" to be enabled. This was missing in the instance.
Vinitha
Hi Vinita,
Can you share from where you enabled "Search On Tab".
VaibhavP5059517
Combination of client script and script include had worked for me.
