Print count and incident numbers for incident with top 3 priorities
Asmita7
Hello friends,
I have a query :
E.g.
Priority 1 - has 50 inc
Priority 3 - has 45 inc
Priority 5 - has 35 inc
Priority 4 - has 5 inc
Priority 2 - has 1 inc
Than i have to print top 3 priority with incident number.
Which approach is better
Viraj Hudlikar
Tera Sage
Hello @Asmita7
Not sure with you usecase but if need code to do so below is sample code:
// Step 1: Get incident counts by priority
    var incidentCounts = {};
    var ga = new GlideAggregate('incident');
    ga.addAggregate('COUNT');
    ga.groupBy('priority');
    ga.query();
    while (ga.next()) {
        var priority = ga.getValue('priority');
        var count = ga.getAggregate('COUNT');
        incidentCounts[priority] = parseInt(count, 10);
    // Step 2: Sort priorities by count in descending order
    var sortedPriorities = Object.keys(incidentCounts).sort(function(a, b) {
        return incidentCounts[b] - incidentCounts[a];
    // Step 3: Print the count of incidents for each priority
    var result = '';
    sortedPriorities.forEach(function(priority) {
        result += 'Priority ' + priority + ' - has ' + incidentCounts[priority] + ' incidents\n';
    // Step 4: Fetch and print incident numbers for the top 3 priorities
    result += '\nTop 3 Priorities with Incident Numbers:\n';
    sortedPriorities.slice(0, 3).forEach(function(priority) {
        gr.addQuery('priority', priority);
        while (gr.next()) {
            result += 'Incident Number: ' + gr.getValue('number') + '\n';
        result += '\n';
    // Print the result
    gs.print(result);
I wrote this code in background script and as per your requirement it works.
For GlideAggregate usage check this video - https://youtu.be/tr4l4GtevfM?si=7mOxc7xbo5IXppoO
Thanks & Regards
Viraj Hudlikar.
