Priority not showing correctly
Pravitha
As per ServiceNow, if the Impact is set as '3- Low' and Urgency as '1- High', the priority should be autopopulated by '3- Moderate'.
PFB the screenshot of the same :
But, after applying the template, the Impact and Urgency, be the same, the priority is showing as '4- Low', which is incorrect.
This happens when I'm trying to create a new call, never tried after submitting the call.
I have tried after submitting the call, then the priority is showing as expected.
Is this the behavior of ServiceNow ?
Can anybody guess why this is happening ?
9 REPLIES 9
Hi Pravitha,
If you use template, if you can choose priority directly,
traverse to sys_template.list and set the criteria you need for the ticket.
PFB screen shot for your reference.
PS: Hit like, Helpful or Correct depending on the impact of the response
Hi Vipin,
Yes, setting the priority while creating a template is fine. Through that we can set the priority as our wish.
Here, we are setting only 'Urgency' & 'Impact', according to that, priority should auto-populate.
I have created a template by setting the 'Impact as 3' & 'Urgency as 1'. Then, the 'Priority' should come '3- Moderate' after applying the template.
But, after submitting the call, the priority is showing correctly as '3- moderate'.
Pravitha,
Can you confirm if your template configuration works fine ?
if not can you let me know is that on OOB incident table or any other table which is extended from Task table?
Vishal Khandve
Hi Pravitha,
try the following:
var glide = new GlideRecord('incident');
glide.addQuery('contact_type','phone');
glide.query();
if(glide.Next()){
if(current.priority == 'critical'){
  current.impact=1;
  current.urgency=1;
else if(current.priority == 'high')
current.impact=1;
  current.urgency=2;
hope this work for you.
Thank you,
Vishu
Thank you for the input Vishu
