‎07-17-2023 02:21 AM
which role can move the Problem to the Root Cause Analysis state from Assess state ?
‎07-17-2023 03:19 AM
Hi @abhisek ,
Roles which can move access -> root cause analysis are:
1) admin
2) problem_admin
3) problem_manager
4) problem_coordinator
For more information refer DOCS here.
Assess a problem (servicenow.com)
‎07-17-2023 03:10 AM
The "problem_manager" should be enough for this as well.
VS
Hello @abhisek
Greetings!
any of these roles:
- problem_admin,
- problem_manager,
- problem_coordinator
Please hit the thumb and Mark as correct based on Impact!!
Kind Regards,
Ravi Chandra.
Hi @abhisek ,
1) admin
2) problem_admin
3) problem_manager
‎07-17-2023 04:03 AM
Hi Abhisek,
To move the problem from Assess state to Root Cause Analysis you need to has role: admin, problem_admin, problem_manager, or problem_coordinator.
Besides, please make sure that the plugin Problem Management Best Practice — Madrid — State Model (com.snc.best_practice.problem.madrid.state_model) is activated to get the new best practice states and guided actions to navigate the lifecycle of a problem.
Then if the problem is valid and requires a resolution, click the Confirm button. After you confirm that the problem needs investigation and a resolution, the problem enters the Root Cause Analysis state.
Please mark my response as correct/helpful as applicable!
