Problem records are closed, but problem tasks are still open
PavanKumar Raja
I have an issue with problem records, when I click on resolve, the problem record is closing directly without checking the active open problem tasks, I need to stop the problem resolving, problem resolve will happen only when the active/open tasks are closed, please help us with the solution.
Harish Kota
Hi Pavan,
You can achieve this by using before update Business rule.
In When to run add the condition as 'State changes to Resolved'
and in the Advanced tab, write the below code:
var gr = new GlideRecord("problem_task");
gr.addActiveQuery();
gr.addQuery("problem", current.sys_id);
if (gr.next()) {
gs.addErrorMessage("Please close the open Problem tasks to proceed to Resolved state");
current.setAbortAction(true);
})(current, previous);
Please hit like/Accept as Solution, if it works for you.
Harish
Harish Kota
Hi Pavan,
if (gr.next()) {
Harish
Excellent, Thanks harish! Solution is worked.
In my question, some glitch is there, but you have understood the issue and provided the solution, thanks for the help.
Gunjan Kiratkar
Hi @PavanKumar Raja ,
You can try below BR on problem table
Before Update
State changes to closed
    // Add your code here
    var grProblemTask = new GlideRecord('problem_task');
    grProblemTask.addEncodedQuery("active=true^problem="+current.sys_id);
    grProblemTask.query();
    if (grProblemTask.next()) {
        gs.addInfoMessage(gs.getMessage("Please close the task before closing the problem ticket."));
Please Mark My Response as Correct/Helpful based on Impact
Gunjan Kiratkar
2X ServiceNow MVP
Community Rising Star 2022
Youtube : ServiceNow Guy
